GFCI at docks for boats
Feb 6, 1998
11,759
Ordered a ELCI from blue seas
Noted the discussion above about an isolation transformer. Is this the galvanic isolator?
So getting ready to install the smart plug, ELCI,and galvanic isolator. So do i install the ELCI downstream fron the galv iso??
So smart plug,galv iso, and then ELCI
Thks
An isolation transformer is not the same as a Galvalic Isolator. A galvanic isolator can only isolate you from "galvanic currents" but not stray current. An isolation transformer fully isolates your vessel the the rest of the marina. The ELCI should be as close to the shore inlet as is practicable, be located so operational access is not difficult and in a hospitable environment.
