Getting the exhaust manifold off..
roy
Feb 1, 2009
186
2 270 soldiers point
Hello all, brbr
I am at the boat right now and have decided to try a few more things before i make a final decision on this motor.brbr
I am trying to see if the exhaust is choked up with soot. I have pulled off the thermostat housing. And, I have the exhaust manifold disconnected from the engine, but i can't seem to get it loose from the piece at the end that connects to the exhaust/water pipe assembly. It is a metal flange that connects directly to the end of the manifold by 4 bolts.brbr
I have pulled, pushed, whacked at it to no avail.brbr
Is there a trick to getting this thing off? br
Is there something I still need to disconnect?brbr
Thanks for any quick assistance...br
groundhogbrbr
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
Nov 11, 2016
96
Nimble Arctic Toronto
If you have removed the four bolts, the flange should come off, unless
someone used some gasket cement (the wrong kind will act like a glue). You
may need to use some solvent or some heat to soften up the cement. By the
way, I looked at my MD6B and it certainly has quite a few frost plugs. Good
luck. Trevor V2915
May 30, 2006
1,075
Thanks Trevor,
Yes, I did see some kind of plug on the lower block area. I'll see if there are more.
Guess, I go start pulling on that flange some more.
gh
Oct 30, 2019
1,459
If you can do it safely, try putting a torch to the flange and the nuts. Keep a fire extinguisher handy and be careful!Nicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.
May 30, 2006
1,075
I went to the hardware store and bought an 18" crowbar and a rubber mallet (now I own two..). Took some reall whacking, but it came loose. It was just permatexed on there. Surprisingly strong. Probably because of the large surface area that was adhered. brbr
Whenever I have the urge to really hit or pull at something, i get scared. I have broken so many things that way.brbr
Thanks for all the help so far. I still have some more questions to come..brbr
groundhogbrbr
Nov 8, 2001
1,818
Hi Groundhog
The gasket for this is very expensive (£50) so that is why they used
that gunk. I expect you will have to use the same when you refit the
manifold.
Cheers
Steve Birch (Technical)
