Getting steamed
3,814
Pearson/ 530 Strafford, NH
I was just looking at some old threads and Roger Long mentioned steaming wood. A little research came up with several types of steamers, but not too much info on the particulars. What types of wood, gentle steam or rolling boil, radius of bend, and over cooking? Years ago I met someone who made sleds and didn't keep in touch long enough to get more info. I've also seen 2X12's bent for handrails and thought that would be useful.
All U Get:zzz:
Ross
Jun 15, 2004
14,693
What do you need to know ?
Ross
Jun 15, 2004
14,693
I can get you many answers but I am not gonna write a book. I have several resources but first I need to know what you need.
Oct 2, 2008
3,814
Hi Ross,
What type of wood, I'm thinking hardwood, and what is the time vs thickness formula? Does the steam have to penetrate the wood at 212F or is it just the high humidity at 200F? What would be the tightest radius for 1/2 or 1 inch thickness? Just basics are what I'm looking for, I'm thinking of some trim in the cabin.
All U Get
Dec 2, 2003
480
Catalina C-320 Washington, NC
Some woods such as hickory and white oak can be bent to tighter radii than other woods. White oak works well in a sailboat cabin and can be stained to look very much like teak.
Make a steamer out of PVC and an old teapot. Get length of PVC of 1/2" greater diameter than the wood you need to steam and 4' max length. Get an end cap to fit and drill a few holes for a vent and a hole in the pipe clear of the cap for a drain. Get a reducer for the other end sized to fit a length of heater hose which you also shove over the spout of the teapot.
Slip the board in the pipe, slip on the caps, hook to the hose and teapot, put an inch of water in the teapot. Clamp the pipe to your grill with the drain end slightly down and put the teapot on the cooker burner if you have one or the grill burner if you don't and fire it up. Don't let the hose loop downward or the condensate will block the steam, this is a low pressure system.
When the steam condensate coming out of the drain is warm, you are probably 'done'. If it won't bend more than the radius you need, cook it some more. When it will bend more then the desired radius, it is done. Clamp the wood in in a tighter radius than desired until it dries. When you unclamp the board it will spring back a fair amount, but should be close enough to what you need.
Let it dry well before staining, the more you cook it the longer this takes.
Ross
Jun 15, 2004
14,693
You will need about 1 hour per inch of thickness, you need to heat the wood to more than 200 degrees f. The wood should be fairly straight grain. You will need a lot of steam. PVC pipe is ok but support it at that temperature. white oak, red oak, beech, walnut, birch,ash, sweet gum, and mahagony are commonly used. the pines and cedars aren't as bendable. When you have half by half inch, good stock, well steamed, you can tie it in a knot.
Apr 29, 2008
13
Oday DaySailer wichita ks
I always liked to use a 2 1/2- 5 gal. round metal gas can set on the burner of a turkey fryer for making steam. Just hook the hose to the plastic gas spout. This works well for steaming large / long pieces of wood.
Ross
Jun 15, 2004
14,693
Now THAT will make enough steam without running dry right in the middle of the job.
Oct 2, 2008
3,814
:clap: This sounds like something to do until the snow is gone, thanks to all the replies.
All U Get
Ross
Jun 15, 2004
14,693
It is wet work and when it is cold you don't need to be wet too.
Oct 2, 2008
3,814
Hi Ross,
I guess the first project will be a comfortable handle for my snow shovel, just when I thought I would have some time. It's still on my to do list, thanks again.
All U Get
Ross
Jun 15, 2004
14,693
Hi Ross,
All U Get
It was about this time of year when I packed my car and loaded wife and son and headed for Kessler AFB ,Miss. it was 20 degrees below with about a foot of snow on the ground in Bangor that morning. I did take my snow shovel with me. I don't need it as much in Maryland.
Jun 26, 2007
106
Freedom F39 Lyttelton New Zealand
When bending a tight radius I clamp a length of badsaw blade around the outside of the bend. This supports the timber abd reduces the chance of breaking the work piece. My first attempt at a steamer used PVC down pipe which collapsed when it got hot, and that was well below 212f. I then got hold of a standard length (8 feet) of galvanised down pipe which worked very well. I have found it useful to presoak the timber for a few days before steaming. - Mike.
