There is a vast difference between electrical shock and electrical burns. learn of the difference.12 volts can absolutely shock you. Think about a dead short across the battery. My brother once got a shock from a battery that spot welded 2 links of a wrist watch together while working on a tractor. Ever try to start your engine by hot-wiring across the solenoid of the starter. Big spark!! I'd check all the circuits to the binnacle and also see if there is any voltage to the steering cables and engine controls. A wire could easily chafe through the insulation.
From a medical perspective, A burn from electrical injury is "shock".Ross said:There is a vast difference between electrical shock and electrical burns. learn of the difference.
