Amazing Problem Solver
Years ago, when I lived aboard my Coronado 35 and had the same pest problem I cam e across a very interesting article in Cruising World on onboard pests. The author revealed a cure for solving roach, spider, etc infestation problems on vessels. Simply, the recipe, which was environmentally safe worked quite well. What was recommended was taking bisquick, baking soda and coca-cola. You make small (pea sized) dough balls using the bisquick, baking soda and coke. Place these behind books, in corners and other DRY places where insects will lurk. What happens is that the coke attracts the insect, the bisquick binds the baking soda which is the "bomb". The insect will consume the pellet and the baking soda will expand in the abdomen killing the critter. I was amazed how many roaches I found dead after a few days that succumb to this simple safe killer. If that slow torture of a insect bothers you, the author recommended the use of "wolf spiders" that will not bite humans in favor of destroying everything on the vessel smaller then them. Imagine one of those guys crawling around your v-berth at night! Try the home-maderemedy, it really works.RegardsBob
