Greetings-
I have been lurking and reading for a while, and checking the archives, but I am sadly running short on available work days. I am the proud owner of Hull #2143, Heretic, and I am getting her ready to go back into the water after 2 years on the hard. None of the stuff that I need to do seems like it should be that hard, but a goodly chunk of it intimidates me a fair bit. I've checked the archives, which has helped a bit, but I need to break down and ask for some help on a few items.
1) I have a new Radar (Garmin 18HD) that I am mounting. The mast is down, and I am installing on a non-gimbled mast-mount. Ideally, I would like to keep the wires hidden - is there a way to enter the compression post to run the wiring in there with the existing wiring, or a successful method of snaking into it?
2) The Radar was part of the package for the Garmin 740S, including a NMEA 2000 bottom sounder. The currently installed 'ducer in the V-berth, however, appears good and thoroughly stuck. It appears to be the factory original, with mounting blocks. Ideally, I should still be able to use that block - or should I consider the Analog-to-NMEA converter kit Garmin offers?
3) Since I have the mast down, should I rewire and replace my VHF antenna?
4) Other pre-splash items I am working on, but think I have a clear path on: wiring up a fuse block into the Nav Table chart locker for Nav Electronics and a seperate one for fans, replacing the steaming/working light and anchor light that were damaged during unstepping, wash/compound/polish/wax (per Maine Sail's column, except I'm still trying to figure out what to use for the Polish phase), and remount the Universal 11 mounts with K50s (using a diesel mechanic unless someone tells me it is stupendously easy and I should do it).
I am sure I'll post again once I'm in the water and the hull and mast projects are done. I had hoped to finish everything first, but... I can drive with charts and a handheld in the Chesapeake for a while.
Any suggestions or advice with the above would be most appreciated.
Jeremy
Cat30 #2143
Jeremy
Cat30 #2143
