Sail Girl
Heat seems like a good idea this time of year. I'm thinking of putting in a Kabola B-tap model B-12 furnace on board. It requires either 24vdc or 230vac for power. My boat has 12vdc and 115vac from shore and from a 2000 watt inverter. The question is, should I get the 230VAC model and use a step-up transformer to power the Kabola furnace, or should I get a device which will take 12vdc and make 24vdc for the 24vdc model of the furnace? Where would you suggest I get equipment for either approach?
