Alternator Output and Internal Regulators
DaveYou wrote: "which I guess is regulated by the voltage regulator."If it is an internal regulator, you're not gtting much of anything out of your alternator, regardless of which size it may be.In lieu of us writing another book here about an already well covered subject, take Guy's suggestion and get Calder's book. It's the best investment you'll ever make for you and your boat, especially the electrical systems. (See other posts in this 24 Hour Activity period that also recommend that book.)You can also access websites from alternator and regultor manufacturers, like Xantrex and Balmar, and gain firsthand knowledge of their products and how charging systems work. The West Marine Advisor columns are also good sources of information on products and systems.That'll give you some homework to do, but you'll you'll be getting it from the right sources, and saving repetition from us, so then you can hone your questions down to more specific requests.Good luck,Stu
