genset location
G
Guest
Where to locate genset on Cat 36? Lazarette? Problems? Type of gen that is quiet yet dependable and powerful enough to use 16,000 ac?
Dennis Thomas
Glad you asked!
I’m glad you asked. I hope someone has a good answer. I have an older 36’ (Hull # 34) and would like to add a genset myself. For the 16,000 BTU A/C we will need at least a 3 Kilowatt system. A 2K set might get by but it would be under max load all the time. Fischer Panda makes the best, quietest gensets on the market – and they’re diesel! But they are expensive and very heavy. Were I to consider one of these I would take some of the space in the aft stateroom (our garage). They are water-cooled and the exhaust can be routed out with your power plant exhaust. I saw one at the South Hampton Boat Show a few years ago and you could hardly hear it. I also saw one being installed in a newly delivered 36 MkII. It was being installed under the seat in front of the sink. That’s where my fuel tank is located. A more economical solution would be a pair of Honda 2000 watt portables. They can be linked together to synchronize the voltage output. I’ve heard from a couple of others that they use a single 2000 to power a single “window unit” type A/C. You might be able to build a sealed box in the port lazarette and provide exhaust and cooling ports that would guarantee that no exhaust would enter the boat. I’m not sure if there’s enough room in the aft locker if you’re on an older C36 like mine. You might also add some soundproofing around the locker. As we only use the aft stateroom for storage, I am leaning toward modifying the rear of the engine compartment to take advantage of the existing ventilation and exhaust plumbing. S/V Anodyne
Russ
Aft Lazarette
A friend of mine has a 1986 C36 and has a Westerbeke 4.2 mounted inside the aft lazarette. I have thought about doing this on my 1984 C36, but am concerned about vibration, noise, reliability and general complications. He has had nothing but trouble with the Westerbeke he said he would NOT buy again. He said he'd probably go with the Fischer Panda 4.2 if he had to do it over again. Dont know if this helps - I currently use a Honda EU2000i portable gasoline generator which I place in my dinghy at night to run a 8000btu window unti in the forward hatch... works fine and makes the cabin comfortable at night but is a real pain in the butt to set up and looks like hell. You can barely hear a slight "humm" from the generator while down below and there is obviously NO vibration noise with the gen in the dinghy. Evan nearby boats cant hear the generator as long as they are about 100' or more away. Russ
