Hi All,
In my home there is no electric grid supply. Hence I have implemented the following configuration for electric usage
1- 150 AmpHr 12 inverter Battery - 2 #s
2- 24 Volt input 240 V AC output -- 1600VA Inverter
3- 600Watt Genset.
Setup/working:
1- 2 batteries r in series 24 V with inverter.
2- everyday genset recharges the battery till inverter shows "fully recharged"
The setup used to work well for last 18 months untill one of the batteries dies completely.
Question:
1- Is this a correct configuration ?
2- Can 600 Watt of solar panel replace the genset ?
3- What might be the reason of battery went dead ?
4- Battery company says, genset shuld nt be used for charging. Is it so?
Thanks in advance ....
Thanks
3- 600Watt Genset.
Setup/working:
Question:
Thanks
