I've seen some previous posts on this but no clear answer. Will the cockpit coaming track be in the correct position to accept a 135 or 150% genoa? We currently are using the less than 100% jib which uses the fixed blocks on the side decks. Is anyone using a 135 or 150 currently? Are you using the cockpit coaming tracks? Do the sheets lead correctly for proper trim? What happens when the sail is rolled up to 100% or less? Cleating is not a problem since I'm using self tailing sheet winches.
