Genoa track for 97 Hunter 26?
C
Chuck Lyman
I am a sailmaker in Puerto Rico. I have a customer with a H26, with swept back spreaders and no backstay. The only headsail block is a pad block for the standard jib. The owner wants a larger headsail. This would necessitate a genoa track outboard at the toe rail. It looks like it would sheet cleanly inside the uppers, and be far enough outboard so the leech would not intersect with lower shroud, as does the jib lead to the fixed block. Anybody have any experience with this concept? My main concern is the strength of the cabin to support the loads of a genoa. Looks like track could be mounted vertically on the toe rail or horizontally just inboard. Any insights, experience or ideas would be greatly appreciated. Thank You
Tim Osborne
Genoa Tracks - just installed
Hi Chuck, I can give my two penneth worth ( cents? ) regarding the same situation on my H240. I'm not sure if there are any major differences when it comes to the coach roof, but I too had concerns about lifting the coach roof off when sheeting in hard. At the end of the day though, I came to the conclusion that the load spread more evenly over the length of the track ( around 3ft ) would be no worse off than the single block. I also feel that the loads experienced, even with a larger genoa are nothing like those on yachts which aren't so 'mainsail powered' and rely more on the Genoa giving poering the boat - it's rarely necessary to use the winch in anger for example - and they're only small winches anyway. I gained access to the bottom of the track through the access panels for the winches and the existing block to make sure that at least some - and the most commonly used sections of the track are well supported underneath with backing plates. I guess I was more concerned at first with pulling the track off the coach roof. This gave 6 good fixing points - ( if you're agile with your fingers you can reach someway under the coach roof from each access panel - patience is also a virtue!! ) and the rest of the track is screwed down at 4inch centres using 3/16" self tappers and the whole track fixed down with a glue/sealant. I've tried pulling damn hard on the cars from all angles, and using the winch - no nasty sounds as yet and it does 'feel' very solid. The sheeting angle is tight at full sail and you're right in keeping an eye out on the inner shrouds. For this reason I went for 125% as opposed to 135%. Not as yet tried in anger yet - it's too cold over here in the UK - roll on spring!! Hope this helps - could supply a photo or two if you're interested. Regards Tim Osborne UK
Jeff
130 Genoa
Chuck, My '96 H26 has the tracks mounted where the deck and hull joint meet just above the rub rail. They are positioned just ahead of the stern rail seats. The tracks are about 3 feet long. The furled genoa's sheet is lead outside the shrouds back to the track then up to a block clamped around the leading support for the stern rail seat and on forward to roof top winch. Works fine for us, though it would be nice to have two more winches located farther aft. "Festitity" 1996 H26
