Genoa sizing
Nov 19, 2012
30
Hunter 33C Jensen Beach, Fl
Hey Guys and Gals,
I am looking at purchasing a new genoa for a '79 Hunter Cherubini and am not sure what size I will go with. I am not a hard core racing junkie, but fast is fun. I am looking for something that would be good for all around cruising. I would love to hear your thoughts, concerns and experience.
Thanks,
Bill Reader
Hunter
'79 Cherubini
SE Florida
Nov 8, 2007
1,613
Consider an asymmetric cruising spinnaker
A big genny, 130 to 155, is a light weather racing sail. With crew as ballast. It is the best way to go to windward in light to moderate winds.
The minute you ease off the wind to a reach, it soon loses its shape, and becomes a problem!
We carry a 110, a Doyle Asymetric, and a 130 on Lady Lillie. The Asymetric is a powerful, effective sail on any reach, from 65 to 150 degrees off the true wind.
Hoisted in a sock, the Asymetric is easily switched with the 110, when winds die down, and back to the 110 when they pick up again. Shifting from a jib to a Jenny involves dropping one sail, and raising another, which takes us much longer than hoisting the sock, and deploying the Asymetric.
I see so many cruisers dealing with mis-shapen big gennies, healing excessively, and trying to make them work when they are simply the wrong sail!
Enough said. Good luck with your decision.
Nov 19, 2012
30
Thanks David, Is your Genny on a roller furling? I guess what I'm really looking for is, does an asymmetrical hoist similar to a regular spinnaker, so that if my ginny was rolled up on the roller furling I could still fly the asymmetrical without removing the ginny?
May 24, 2004
7,213
CC 30 South Florida
Get a 155. The boat can handle it in a stiff breeze and will provide best performance in light winds.
Nov 8, 2007
1,613
Yes, we have a roller furler
We have a roller furler, usually with the 110 on it. 110, or 130, when its rolled up, there is no interference with the Asymetric.
Most asymetrics come with a sock. So shifting from the 110 goes like this:
- furl the 110.
- hoist the top of the sock on the spinnaker halyard.
- rig the Asymetric sheet and tack lines.
- raise the sock which deploys the assymetric.
- trim the assymetric, and off we go!
Reverse the process to go back to the 110.
We do sometimes overlap the process, leaving the sock up, and unfurling the 110, etc.
The 155 is a great sail for going to weather in light winds. At 70 degrees off the true wind, the Asymetric already provides far more power.
On a beam reach, the Asymetric is incredible, and the 155 is totally out of shape, providing more healing force and drag, than drive!
Jun 5, 2010
1,136
Hunter 25 Burlington NJ
Headsail wardrobe
You can pretty much never go wrong with a good 135, on a furler or not. A 155 is fine but is limited to lighter air (and usually a 155 is made lighter, so even if the boat can handle it, the sail won't, for long).
For a decent cruising boat such as my H25, the headsail wardrobe could include:
110 working jib (5.5 oz)
90/100 'offshore blaster' (6 oz)
125 or 135, general-purpose genoa, medium-light
155 drifter, really light
storm jib, heavy
spinnakers extra.
Sailwarehouse.com carries all of these; they also have a priceless data chart with the sail dimensions of just about every production boat you can think of (including all our 'legacy' Hunters). Their prices are good; and if you do not have a reliable local sailmaker I would go to them in a trice.
Have all your sails fitted with luff tape (
#5 or #6 most common).
I'll say here for about the thousandeth time that if you have a furler that doesn't let you remove and replace sails with it rigged on the boat, in the water, at sea, you haven't really got a cruising furler. This is prime amongst all requisites for a furler. Storm-damage claims are full of people who left the sail on and had it wreak absolute havoc on their boat and on everyone else. I've seen it happen. And I won't even get into how important this feature is during a serious blow at sea.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
135 for Florida
Depends on where you sail. Florida is generally a light air locale. If I were going with just one genoa it would be a 135 for Florida.
