Genoa sheet chafe
Mar 18, 2014
12
Catalina 30 Vancouver
When I ease my Genoa sheet out it chafes against my lifeline. It seems this would cause accelerated wear of the sheet. When close hauled the sheets do not touch the lifelines.
Have I made an error rigging the sheets? Is the chafing less of an issue than it appears?
Ted
Jan 26, 2005
1,274
Not a problem. Just sail upwind all the time. Your situation is pretty typical.
May 1, 2011
5,297
Pearson 37 Lusby MD
Consider rigging a barber hauler when you're on a close reach or broad reach - that would move the sheet outside the lifelines, then to the car. That said, I haven't noticed an issue with this on my boat.
Joe
Jun 1, 2004
8,267
You should install a "genoa track" on the toe rail.... but your stanchions are mounted there.... so invest in a set of snatch blocks that you can clip to stanchion base or padeye and allow you to run a second sheet outside the lifelines.
Catalina 320 Dana Point
Perhaps, you could move the cars forward which you would often want to do while running.
