Gelcoat stain
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
How do I remove stains from gelcoat?
I was removing Horizon ablative paint near the waterline using sodium hydroxide type remover. Some of the loosened remover and paint mix smeared above the waterline. Now I have a green stained gelcoat.:doh:
caguy
Sep 22, 2006
4,004
Try bleaching it out with Clorox. Do not dilute, wear eye protection, gloves and an old shirt. It will take a few minutes to react. Then rinse.
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
Have you tried FSR, that gel stuff with oxalic acid in it? Seeing as how it's paint, you might need to compound it out.
RichH
Feb 14, 2005
4,773
Quoddy -
suggest you - Soak the stain with the SAME hydroxide cleaner that you used previously. To enhance the 'extraction' you might consider to put a covering of plastic film (saran, etc.) over the cleaner, to enhance and prolong the soak time.
For any 'shadows' remaining attempt a bleaching with oxalic and/or bleach and/or an acid based toilet bowl cleaner.
For remnants/shadows still remaining .... begin with 1000 grit wet and dry sandpaper and go progressively 'up' to 2000 grit or if needed 'down' to 600 grit. End with 1500- 2000 grit then compound (3M Finese-it™ ---> 3M Perfect-it™) Dont be afraid to 'hog down' into the gel with the wet-sanding as most production boats have plenty of gel thickness for a 'few' heavy wet sandings .... but do STOP sanding/buffing if you begin to see the underlayment/matting layer beginning to show through.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
If you haven't already tried just using acetone and a rag, try that... next try on and off, it's available at west marine.
as a final option, you can always try some 1500 grit wet/dry sand paper, you'll have to compound and polish again after that though.
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Thanks
Thanks for the suggestions. I did try acetone, which has worked in the past on things, but no luck on this. I will keep trying as suggested.
