Gel coat cleaner
94
Catalina 22 Cape Cod
PoliGlow . . .
Everyone has their favorite, and mine is Poliglow www.poliglowproducts.com The "waxes & polishes" give good results on boats that have a fairly good shine (no Oxidation). The "restorer" products (Poliglow, Island Girl, Vertglas) work well on really oxidized surfaces. If you transpose them, you get bad results. i.e. "restorers" on fairly good fiberglass gives poor results as does "polishes" on oxidized fiberglass. It sounds like you are in the "restorer" market. Practical Sailor Mag. rated Poliglow the best of the D-I-Y products a while back. I've used it several times with fantastic results. (My 2 cents)
Dec 31, 2004
85
- - Guilford, CT
Poli-Glow, too!
I have used Poli-Glow on my boat and been asked if I had repainted it, it looked that good. I'm sold on their product. A friend tried IG and went to Poli-Glow because of poor results. Much happier now with PG. My .02. Ellis
Dec 2, 1999
15,184
What does a complete job cost?
Robert: What do you charge for a 30' sailboat (in the water)?
Jun 2, 2004
3,644
It Was $25 a Foot Here
The Yard gets $15 a foot to paint and and buff the hull. Another guy gets $10 a foot to do the topsides. I bought a buffer and did it myself with the Aquabuff stuff not hard to do just takes some time.
Peter
Island Girl
I spent a lot of money on Island Girl too. I found that it doesn't even come close to 3M in quality and shine, and 3M was about 1/10th the price and hassle. And yes I followed the instructions. To each his own I guess. Peter
Duane Maher
Island Girl Products
I have been a long time user of IG products. I have never used them to restore old deteriorated gel coat but I have used the products to maintain the gel coat in like new condition. For example I just bought t a new boat. And the builders did not do a great job in cleaning the adhesive off the nonskid. I used IG Pink, undiluted and let it set there in the hot sun for about ½ hour, went over with a stiff brush (did this a few times) and rinse with plenty of water. Most of the adhesive was gone. Couple of things you have to understand about these products. They like warm weather. Pink can be highly diluted (a little bit goes along way ,some folks use way too much ) and it should be rinsed with plenty of water. Silken Seal should be used before applying IG’s wax or Mirror Hard for the first time. I really like the Sea Glow and Silken Seal. It really works on the fenders and lifelines. The trick here is to use the 000 scuff pad. The products are not your typical petroleum base products, therefore the behavior can be different so it can be a learning process in using. I now only use Island Girl Pink for all at home cleaning. I just removed blueberry stain from my favorite shirt. If you have any questions. You can email me at duane@maher.name BTW, I have no finical interest in this company and I pay the regular retail price for the products.
Bill O'Donovan
Island Boy
Island Girl works if you follow the directions. I use a 50-50 Pink to hot water once a month, with a quick touch up using Mirror Hard, and inbetween just hose off with Dawn. The waxes are highly penetrating and work well on stainless steel as well. The proof is in the beading and the general appearance. Sure the boat is going to get dirty, that's not Island Girl's defect.
T Hudson
From another Pro detailer
I switched to Island Girl Products 5 years ago. My customers are really happy that I did. In general, it's easy to apply and maintain and last a long time. If anyone has a problem, Mr Willis will bend over backwards to help you solve it. A real nice personal touch... and appreciated. Don't forget that Island Girl is a system of products and not just a wax and treats all areas of your boat, RV, airplane or car. The SeaGlow restores vinyl cushions, lifelines, power cords, and fenders to 'bout new condition. It also restores oxidized hypalon and makes your dinghy practically look new. Easy on the("or other name products in boat stores) that some people use on plastics. All in all, there is no perfect wax or cleaner but, The Island Girl products that I use are the best for my customers and ultimately... me.
T Hudson
Capt. Dave
Before you give up on the Island Girl... spray that area with water. I bet that you'll see water beading like crazy. To bring back the shine, take a paper towel and spray some IG Silk N Seal on it. Rub (don't have to use much pressure... just gently wipe) in a circular motion. You'll see the shine again... big time. By the way your Morgan looks great. If you have any surface rust, try a little Sea GLow on a 000 scotch pad and watch how it removes the rust. The same product will bring most vinyl back, too.
N
Natalie
Island Girl - Great For Oxidized Boats
I own a detailing company in Seattle and we normally use 3M cleaner wax with a buffer on medium oxidized boats. I bought the IG Sea Glow, SilkenSeal and the Super Wax to try on an oxidized Bayliner. The hull was chalky and had black marks on it from running into the dock. We did part of the hull with the 3M cleaner wax and a buffer and we did the other half with the IG products. I was absolutley amazed! With the 3M side, we had to use a lot of elbow grease to get those black marks out by hand and then used the buffer on that section. It came out alright, but it needed more compound and could have used a polish afterwards to make it look better. The IG products made it look glossy and smooth with out using any elbow grease! We had the owner come out and choose the better result and he chose the IG side. He didn't know his old chalky Bayliner could look so good. Yes, you do have to read and follow the directions, but practice a few times on a small section of your boat until you've got it down (when you're getting the results you want). It's worth it in the end!
W
WholeHeart
Understanding Gel Coat
I've only worked a little with IG and the results so far are worth the time. One must understand that gel coat is not at all like paint. Gel coat is porous and cleaning it posies new challenges. I grow up around the auto body business and auto detailing. 3M is just fine in that area but for boats I have to say that I'm not all that happy with their products. I'm a person that likes to work with products side by side and compare on different boats. The truth is there is no single one product that covers all boats. New gel coat needs different care than old gel coat. Even gel coat seems to differ from manufacturer to manufacturer. I'll use one product on a certain boat in a given condition and then on anther boat that appears to be in the same condition I'll end up using something else after trying side-by-side tests. There simply is no one right answer, you have to try and see what you are happiest with. Right now for a new boat I like the StarBrite Teflon polish. For a new boat with stains that needs to be removed but I don't want to add marks from abrasive cleaners/waxes I like the Gerry's Royal Satin Cleaner/wax. It uses a chemical cleaner. In the end it just each to his own and what a person likes to work with. Are you applying by hand, by professional circular polishers, by random orbital polishers? Just try products and see what you are happiest with, there is no set answer even if we all wish there was. And then sometimes you just give up and paint the decks! Don't even ask what kind of work that is if you do it yourself. But if you do decide to do it yourself research, research and then find someone that will pay you to work on you own boat and send me their name and phone number! Suzy S/V WholeHeart E34 Seattle, WA
Peter
Buy my IG stuff if you like..
Well, like I said, I tried it a couple of times on a very oxidized boat, and yes I read the instructions many times. Anyone in or coming to Sidney, BC is welcome to buy the IG products from me very very cheap. Peter
Dave
Island Girl Product line
I’ve been using IG products now for a number of years and I’ve been completely satisfied with the outcomes. What really was the deal breaker for me being a complete skeptic on just about everything was that I took my 1982 Hunter 33 and did one side of it with the 3M product and the other with IG, At the end of the season (northeast) the water stopped beading on the 3m side of the boat while the IG side was still very good. The following season I did the 3m side with IG and went over the original IG side again and doing the IG side again was oticeably easier than the 3m side. A big plus for me because I really don't like this type of work. One other thing I noticed was that every year mold spores would for form on the gel coat under the dodger where not a lot of sun hit. Using the IG product, that didn’t happen. Again being the skeptic that I am I contacted IG and Dr. Willis told me that the product was a gel coat sealer and prevented moisture from getting in the pores of the gel coat which is where the mold grew. I don’t know if that’s the case but I don’t have mold spots anymore. One last thing. I got a complement on the boat the other day. They said that the hull looked great for a 23 year old boat. That says it all. Dave PS. I don’t work for and this is not a paid announcement for IG. Just a satisified consumer.
Jun 6, 2005
49
Pearson 10M Tacoma
What about 303 Protectant?
I need to tackle this job soon myself, and I read in a forum (can't remember where), that a bunch of sailors use the UV protectant 303 instead of wax. A couple guys said "I'll never use wax again!", etc Does anyone here have experience using that product on gel coat? (I don't.) If so, would it only replace the wax coat after the oxidation had been removed using something else? Craig
May 26, 2004
168
- - Oriental, NC
Dull streeks in IG
I am just starting out using the IG system on old gel coat. I have been following directions and have numerious conversations with Dr. Willis. He really goes the extra mile. The problem that I am having is that inspite of thin coats of each product, wiping to dryness and a whole day of 90 degree plus drying when it rains I get dull streeks where the rain water ran over it. Have any of y'all had that problem and if so what was the cause. I really like the system and want it to work, but the dull streeking is bad. Even though the video doesn't imply it, is there a waiting time between steps. Thanks for any ideas. Good Winds Dave M s/v DAMWEGAS
jimq26
Jun 5, 2004
860
Try it - it works!
Craig - I used 303 Aerospace Protectant this year (back in April before launch) and I swear, I will never wax again. We haul out on Oct. 30 and my topsides look sparkling and new (1973 G-26). All those previous years I waxed for hours but the boat never looked as good as it does now. I did some of my deck with it as an experiment, and it looks brand new as well. I think I am the only one in the yard who used this new product this year, but I'll bet there will be some more next year when they see how it stands up to the UV over the summer. Wax just doesn't last. You have to read about the product and read the testimonials to understand how well it will work. They will send you a free sample to try. I tried a sample last fall, and then ordered the product in the spring after I saw the results.
Sep 30, 2005
1
- - Apache Lake, AZ
New IG Fan
About two months ago I tried Island Girl products on my dark green, 1982 Freedom. In Arizona all gelcoat takes a terrific beating from the sun, and dark colors are the worst. In years past, I have looked forward to the yearly (should be twice at least) drudgery of the hauling, cleaning, compounding, waxing, with ever waning enthusiasm. This year, after putting it off as long as possible (actually too long), I bit the bullet and got out the stuff, including the Island Girl box, and a big bottle of 303, which is used by a couple of the other owners here as a no-hassle, no prep finish. As I'm trying to decide where to start, my wife walks over and hands me a package of Mr. Clean miracle sponges to try on the oxidation. More to please her than anything, I tried them. WOW. The oxidation came off like magic! The surface was smooth and dull dark green after just an easy scrub and a good rinse. This was the least work I have ever done to prep the hull, so I went ahead with the finish. I did one side of the rudder with the 303 and the other with the Island Girl products. Then I asked all of the residents of B-dock to pick their favorite side. It was hands down for the Island Girl side, much shinier, so what could I do but use the IG or buy enough drinks to calm the uprising. The boat hasn't ever looked this good! Someone else on this thread mentioned that 3M was great for cars but not so great for boats - I'll give that a hearty second. I'll let you know how the IG holds up in the Arizona sunshine over the long haul, but for now it is definitely the best finish I've seen, and the sponge thing made it soooo much easier. And yes, Dr. Willis is a real person who will really talk to you if you have questions.
Jeff D
Gave Up On IG
I gave up on this product. My personal experience and opinion it is too expensive, labor intensive and as you can see people have mixed results. I have often wondered if there was a QC issue with these these products. The non-skid solution attracted dirt like crazy and it is now just wearing off after 3 years so I can finally clean the decks. Whenever I had a problem the solution was to use another one of the never ending IG products. I think Aurora non-skid wax worked great on the decks. The series of IG products just was too big a hassel and the results were just so so in my opinion. THe 303 looks pretty interesting. I need to do some more investigation on that.
Jim Willis
A detailed reply to Pete, Dave and Wholeheart and
Pete: If you are actually a bona fide customer. Just send the product back to Island Girl for a refund. Don't use the address on the website, but send to my home/office at 237-A Kihapai Street, Kailua, Hawaii 96734. 1-800-441-4425. You can e-mail me first at islandgirlproducts@mac.com. If you bought from sailboatowners.com, or Lats and Atts, I will work with them on re-imbursement. However, I will need to talk ("grill?") you on the phone for details, so that I can learn from your experiences, with regards to age of gelcoat, did you use compounding with 3M was the weather cold and wet etc. When did you do this - did you use our flow charts & DVDs etc. I really don't need to modify the products anymore since I test every batch on a variety for surfaces from new and old auto paint, reasonably old but IG'd gelcoat (my boat and several boats we detail in HI) as well as some REALLY chalky gelcoat (that grey gelcoat shown in the 3 steps instructional movie). I test each of the nine products myself, in tropical conditions, for advertized effectiveness for length of beading with coatings (at least 2 years with SB Superwax), reasonable shine on white for about one year before touch up, about 6 months on dark green etc). That is why I personally sign each bottle! Now, we did have a shelf-life problem with two products (SB Superwax 5 ears ago) and non-skid sealant (3 years ago)) but that has long since been addressed. I can say with great confidence that if the product don't seem to be working in the "standard" way, contact with me through the tech line (now 510 868 0208) will take care of the problem, providing that you follow our advice. "wholeheart": It is good that you pointed out that points out, gelcoat has varying degrees of porosity that could cause variability in the "only two coats needed" standard recommended coating with the SB Superwax. Indeed, I remember a guy in Florida whose boat looked so great that the guy next to him wanted to use the products on a boat os similar age, but the intitial results were not nearly as good (surface dulling). We later fixed that with introduction of the the catalyst and (especiallly) the silkenseal undercoat with recommendation for extra coats of SB Superwax as necessary. jimq26: 303 was originally introduced as a is sort of a suntan lotion for vinyl. If it shines it has silicones (which will eventually dull) and the anti-oxidants should soak in an prevent new oxidation. The oily consistency (remember penetrol?) should give some depth to darker gelcoat. On white, look out for yellowing that used to be a problem about ten years ago with 303 . On a neglected boat you still need to remove the surface oxidation and smooth the surface since there is no "filling" ability as with poliglow, IG's Superwax or even paste wax. I am going to film some side by side comparisons on my own boat this weekend as this product was never previously accepted for gelcoat in spite of claims that go back about 10 years. The great thing about 303 (to me) is use on sails etc to protect against UV and they have stayed ahead. On vinyl it is inferior to IG's silkenseal (especially with Mirror Hard over it) to prevent vinyl gumminess. That it because it does not form a new "skin" We used to recommend it before we had our own surface protectants. However, as I said, I haven't used 303 for years and it is possible that they improved the formulation for other purposes as we have also done over a ten year period. In separate post I have drawn up a pro and con list of various approaches to gelcoat restoration/protection. As you probably know, our aim is to get a system that is universal for ALL plastics of ALL ages without many duplicated products as saold in chain stores. One thing that I am gratified to see on this thread is slow disappearance of undocumented slander to a more "scientific" discussion of product comparisons. We have movies of various results on the IG website all but 3 (on IG Pink) are available as links from the chandlery on this site. Thanks Jim Willis
Feb 12, 2005
143
- - Lake Worth, FL
John Wills, do you have a sample or test pack?
to test a small area? I would even be willing to pay a token ammount and shipping, I just cant spend 150$ on a untested system, but i am more than willing to spend the bucks on something that has been proven to work on my own boat, even if just for a few square feet.
