I am a new owner of a 1988 Catalina 30. It is very very difficult to shift from neutral to forward, and back. Do you have any suggestions for fixing this. It's really nearly impossible.Thanks
Check the linkage, lubricate all pivot points, ... test. If no change, a new cable is indicated.PS. I think I should have spelled my name Juan, not Jaun.
Juan might have also mentioned adjusting the shift linkage. Keep it a little stiff, but not enough to make it difficult to shift.Doesn't your boat manual explain this procedure? Chuck
