Gear ratios
May 17, 2010
99
hunter 33 marina del rey
I have a 2005 hunter 33. I'm planning to get a Kewi prop. The prop people need the model engine [I have that] but they also need the gear-ratios, which I don't have. Where can I find it?
Thanks in advance.
Nov 6, 2006
10,256
There is a plate on the transmission case that has the ratio stamped on it, along with the model number and serial number.. Access can be a bugger sometimes.. ya may need a mirror and a wipe to clean it off.. On my transmission, the label is on the starboard side just below the oil dipstick. Yours is probably in a different location.. Good luck.
