Gear position under sail w. left hand prop
Jan 15, 2013
4
Catalina 30 San Diego
Hi All,
We have a 30' Catalina whose previous owner changed from an Atomic 4 gas engine to a small (10 hp) Volvo-Penta diesel. It has a left-handed prop. Many sailors say to sail when engine off with transmission gear in reverse. But, if reverse with right hand prop, should it be "forward" with left hand prop. Does it make a difference to engine/transmission wear or to boat vibration?
If arranged properly, the LH or RH prop shouldn't make any difference. However, the RIGHT way to do it is to identify the manufacturer of the TRANSMISSION (not just the engine), & regardless of engine, find out from them, not a sailing forum like this. You know, go to the "horse's mouth."
Good luck.
Sep 14, 2014
1,293
Catalina 22 Pensacola, Florida
I agree, you want it in gear, not neutral, but its the transmission that needs to be accommodated not the engine or direction of prop. Go with advice to contact manufacturer.
Dec 7, 2004
18
Catalina 320 Lakeshore, Miss.
I have never understood why it matters whether you chose F or R. Isn't the point simply to stop all rotation? "Stopped" has no direction of rotation.
Richard, SV Serenity, Catalina 320
Feb 6, 1998
11,762
Because on a Hurth the gear will "slip" in forward and shed metallic bits of the clutch plates into the gear fluid. Once the metallic bits are in the fluid they begin to eat away at the thrust bearing until your gear begins to slip when running the engine.. Reverse locks it and it won't rotate, forward does not and causes major damage.....
If you have a Yanmar then you need to leave it in neutral....
Dec 7, 2004
18
Re. Correct Gear Position Under Sail
Thanks, guys, for the input. I have a Perkins/Hurth combo, so it looks like reverse for me. I had always thought reverse was correct but often forgot until I eventually would hear a rotating sound coming from below.
