Switching Ball Valves
I've almost repalced all of mine on an 89 Hunter 40. I found a pipe wrench necessary, but also went to Home Depot and purchased a plier-like channel lock, but the jaws were curved to wrap around plumbing fittings. Took up a lot less space in those tight quarters, and still produced good leverage. The larger valves were well seated. I would also suggest using a underwater suitable dope in lieu of teflon tape. The thru hull fitting is typically NPS (National Pipe Straight) while the ball valve is NPT (National Pipe Tapered). Because of that, you don't get that many threads to engage for a true thread seal. There's some good debate about even using a "ball valve" in place of a true marine seacock, but that's up to you to weigh out. It's a lot of work converting everything to marine seacocks bolted in place. Anyhow, I've had reasonable service with the ball valves (10 years), and knew it was time to replace when handles started snapping off. Also, I close and open valves as I arrive and leave the boat. It will help them from freezing. I also went to a local plumbing wholesaler to purchase the same Conbraco valves sold at most of the marine supply houses. I upgraded the valves to 600 PSI ratings and still paid about a third less. Worth a try.My only regret is I miss not having a drain plug for winterizing. I did not think they made that in a ball valve anymore. My mistake was not asking the plumbing supply house, because I later found out I could have ordered them. If you have the time, and can do it, it might be worth it if you winterize.
