		Jesse Delanoy
I just bought a 1982 Hunter 25, with a Chrysler 9.9 hp outboard bracketed on the stern.  The boat has full cockpit controls for the engine, with cables running through booted holes cut in the transom.  When I got her, there were two red plastic 6 gallon gas tanks in the lazarette, with the fuel hose running through one of the booted holes to the engine.  The lazarette, of course, drains to the bilge.  We half-filled one of the tanks with gas/oil mixture, took the other tank off the boat, and left it for a couple of days, hose attached, vent closed.  When we returned a couple of days later, the whole cabin smelled of gasoline.  I have since relocated the gas tank to the cockpit floor,  but I need a better arrangement, as there's little enough room as it is.  It has been suggested that I install a permanent, below-deck plastic tank on the shelf in the lazarette, with a hose venting the tank overboard, and a deck-plate fill hose.Does anyone have experience with an arrangement such as this?  Is it safe?  Will it keep gas fumes out of the interior of the boat?  The yachtyard owner says it will, but I'd like additional input before I spend the bucks.
