Gasket size for Gray portlights on H34
Tom
Anyone know what the gasket size is for the Gray opening ports on the H34? I'm going to replace the gasket and rebed but I want to have all the materials before I pop them out.
C
Craig
Got Mine From Hunter
I got my material from hunter direct. dont know the size and it comes in a line not premade for yourport. i have not used this yet. make sure you do a little research on rebedding if you have not done this and for sure dont use 3m 5200 unless you have a jack hammer for removal down the road. i used 3m marine grade white silicone four yrs ago and it seemed to work just fine. its messy so tape off your area and a tip is to use a cup with very soapy water to dip you finger in to better smooth out the bead of caulk. good luck and it gets better as you go. craig
J. Tesoriero
What size?
I would suggest that you look in the Boat/US catalog and get the Bomar/Gray model number for your ports based on their size. You can then get the right gasket from Boat/US, West Marine or Bomar/Gray by special order. The gasket can be installed using only rubber cement.
Rich Wallace
Call Bomar
They have the correct gasket material in a roll. It has a self adhesive on the back. You peel the wax paper and stick it in the old track. Put the joint at the top center of the port. I cut the material with the cutting tools sold by Sears (knife against a flat plastic packing) at a 45 degree angle. Not a leak since.
