gasket sealent
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Hello all.....
I am replacing my impellor and thermostat and was wondering what everybody puts on the gaskets.
I've heard people using nothing and letting the paper gasket swell and do the job.
Code:
Thanks
Greg
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
Have never used any sealant, paper gaskets work just fine.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I use Permatex Hi-Temp RTV Silicone Gasket Sealant.....a little bit works fine and I use it just for good measure cause I hate putting something all back together and it leaks....been there done that
Aug 16, 2006
281
Ericson 32 Oregon coast
I always liked the old style Permatex for sealant.
Seems as though the replacements, thermostat and impeller , would have come with gaskets. Seems as though trying to go without sealant is a long way to go for a shortcut.
NYSail
Jan 6, 2006
3,187
They did come with gaskets.... definately would not work without it. Just asking what people use in addition. I have used marine teflon grease in the past as well as using nothing. Just want to hear about other techniques/opinions
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
The impeller is something you want to be inspecting at least once a year, so you don't want to do anything that makes it harder to access. One of the most useful engine add-ons is a "permanant" removable impeller cover. So, for sure you do not want to use anything on the impeller cover that hardens or is hard to remove & reseal.
For the impeller cover, i would just go with the gasket, and maybe a bit of marine grease. For the thermostat, also grease, or maybe some non-hardening gasket sealant like Permatex #2.
I don't have alot of experience with the RTV gasket stuff, but I don't think I'd use it in either of the above applications.
NYSail
Jan 6, 2006
3,187
Yanmar 3hm35f.... no name on pump... impeller is Johnson
NYSail
Jan 6, 2006
3,187
put a film of teflon grease on gasket and no drips.... Now onto the thermostat.
Thanks for all the input once again!!
Greg
