Gasket Lube
  • Thread starter Paul (Affinity C320)
  • Start date
P
Does anyone know what product to use on rubber gaskets -- those around windows etc. Thanks.
Ray
Mar 10, 2006
94
Hunter 26 Kettle Falls Wa.
To install, preserve or stop leaks?
Paul, Knowing what you are trying to do would help as all these require different products. Ray
A
AL Hughes
O ring lub
Hi Here is a product that I use on rubber O rings. You can check it out to see if it will work for you. Parker O Lub,Comes in a tube. It is made by Parker Seal p.o. 11751 Lexington Ky 40512 I use it on my head pump Rubber O rings and other rubber O rings. This O ring Lub can not be used on Hydraulic Systems. A 4 oz tube has lasted me about 5 years. Fair Winds AL
Jul 12, 2004
285
Catalina 320 chestertown
To Preserve
I don't have any leaks. Just trying to get ahead of the game to preserve and prevent problems in the future. Thanks.
