Gas Tank...
walt
Jun 1, 2007
3,541
This would be worst case.. but what if you filled the ballast tank and unknown to you,, something got partially sucked into the hole at the bottom of the boat such that when you tightened the valve, the foreign object made for a poor seal. Then, you accidentally bump the glued on fixture and it breaks off. If this did happen.. I think the chances are very high that when you have full supply load (food, water, lots of gas in the rear, all those panel also in the rear) you would have a good flow of water come in through the hole.
If the boat is relatively lightly loaded, no problem - I know others have said they have no leaks with the stock setup but one time I had left out the inspection hole plug and the valve was not tight and I ended up with a lot of water under the starboard seat.
My moron proof solution (since I end up being a moron about 1/4 the times I go out) was to put a pool around the valve and access hole. As long as the water line does not go above the pool, the boat wont sink. The top of the pool is way above water line - even when I'm heavy loaded.
Yup, this protects against a condition which probably wont occur and probably is of no use at all if your always lightly loaded.. but sure gives me peace of mind when the whole family is on the boat in 300 foot of water..
By the way, nice job on the gas tank..
Sumner
Jan 31, 2009
5,254
This would be worst case.. but what if you filled the ballast tank and unknown to you,, something got partially sucked into the hole at the bottom of the boat such that when you tightened the valve, the foreign object made for a poor seal. Then, you accidentally bump the glued on fixture and it breaks off. If this did happen.. I think the chances are very high that when you have full supply load (food, water, lots of gas in the rear, all those panel also in the rear) you would have a good flow of water come in through the hole. ...
Hey Walt that is a lot of ifs ;). I guess I'd do what we did when I was a kid and we were canoeing down a wilderness stream that no one had been down for years and we tore a hole in the bottom of the canvas canoe. We put a cushion over the hole and my mom sat on it :). I guess Ruth and I would have to flip to see who would sit on the cushion :).
Actually I think I could stuff something in the hole to slow it down and we do have the bilge pump now, but I like what you did and might follow your lead at some point, but not enough time now.
One reason I added more JB weld to the fixture was to try and avoid what you described. I've given it the yank test and it seems awful strong and it is in a pretty protected location still it looks like you have a good solution,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac-Venture Links
walt
Jun 1, 2007
3,541
I think one nice thing about doing lots of work/mods on a Mac is that you really understand the boat - and when you run into a problem out on the water, your better equipped to just take care of what ever the problem is.. Your right, I think there are other "better" things in life to worry about.
Jul 7, 2004
8,496
Hunter 30T Cheney, KS
Plus it's more likely that you know what tools and parts to keep onboard.
Would a list make a good sticky topic?
