Gas Spring Prop for Chart Table
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Got tired of holding up the chart table on my boat while searching for stuff underneath it. Based on another post, I decided to make a prop for the table using one of those high-pressure gas springs.
I got the parts over the web from McMaster-Carr. They arrived the day after I placed he order. McMaster has the springs in both carbon steel and stainless; I decided to try carbon steel for a few reasons: a) I thought the below-decks location didn't require stainless, b) the CST parts are considerably cheaper, and c) I wasn't entirely sure if the gas spring would work.
I picked a 9416K351 gas spring with 15lb force, 15.6" extension and 6.3" stroke. To this I added two each 9416K86 ball socket ends, a 9512K97 ball bracket, and a 9512K92 ball bracket. The total cost including tax and shipping was less than $25.
The attached photos show the parts and the finished assembly. I had to play around with the location of the brackets to get the lift force right, but once I got it dialed in the system worked great. It easily holds the door up while not requiring much force to close. The gas spring and brackets do take up a little room in the chart table, but overall, I'm very pleased with the result..
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Gary, I have a pretty heavy table top also, use a piece of Pinrail to hold it open for 15 years, this summer I was rummaging around in desk, my elbow hit the holder, hit me in the schnozz, I was seeing stars.....I am going to check out McMasters..... Red
Jun 25, 2009
542
Hunter 33 Seabrooke, Houston
What a great idea!
Lousy navigation table on my H33 : has anybody out there made a change, such as in the above posting, where you lift up and have an inside compartment?
Any modifications?
Jorge Fife
If it's flat and it lifts up, it should have an edge. Put a hinge or two on that edge if you have room - like a flat door.
