Transducer
slidewhiz,I recently installed a new Garming 498 in my 37. I strongly believe in as few holes in the hull as is possible. I epoxied the transducer in the bottom of the hull, and it works very well. If you have a newer boat, with a composite hull this may not be possible. It will work well through solid glass, as long as there are no air bubbles. To find out, easiest way I know is to put the transducer in a baggie of water, sit it down in the hull and see what happens. With this method you can move it around and see where you get the best results in various locations. Some use various materials to put mount the transducer, and you will more than likely get some other opinions. I used Marine Tex to mount mine.
