I Have check most of the threads on this subject and found nothing that could help me, the one I tried did not seem to work, this is my case if some one can help me:
Garmin 545 chartplotter to Raymarine autopilot ST4000.
Garmin has two NEMA ports: Blue wire port 1 Tx (out) Brown wire Rx (in) / Grey wire port 2 Tx (out) Violet wire port 2 Rx (in) also Red wire is power (10-32 Vdc) Ground. Raymarine ST4000 has a NEMA port Blue wire (Data in -ve) and Red wire (Data in + ve).
I have tried every different combinations including changing communications protocol to no avail. Has anyone been successful doing this setup? I don't want to use a seatalk interface box if possible.
Thank you all.
Gene
Thank you all.
Gene
