Garmin GPSMAP 76
Jerry Raznov
I just purchased a new Garmin GPSMAP 76. I downloading and installed GARMIN GPSMAP76 Software Upgrade Version 3.41 to my GPS. This unit has a functional problem that will not allow it to generate Routes in accordance with the owners manual, page 48, paragraphs #1 & 2. These paragraphs state, "Start a new Route page. Highlight the blank route entry line. Hit the menu button and select Use Map. Place the Map Pointer on a Waypoint/Map Feature and press enter twice. The GPSMAP 76 will store that location only to the new route using the feature name as a reference. These points are not stored in the User Waypoint List." My GPSMAP 76 will only allow me to enter 2 lines of route data using this technique. Additional lines can only be completed by first using the Map Page and Map Pointer to identify a Waypoint/Map Feature and add that point to the User Waypoint List. This operation takes additional time to generate a New Route, does not comply with the owners manual instructions and eliminates a capability that was an important reason for my purchase of the Garmin GPSMAP 76 unit. Garmin Tech Service confirmed via a new unit that the problem exists and will investigate and reply soon. Does anyone have the same problem and if so was Garmin contacted and what was there reply? Thanks.
John K Kudera
SAVED
I think I remember the instruction said to save your routes before installing the updates, Mine are still in there. Garmin GPSMAP76S
