galley sink replacement
boz86
Sep 30, 2012
29
Hunter 31 Pasco County, FL
Anyone found a galley sink replacement for a 31'?
Scandvic doesn't make one although they're going above and beyond to help me find one.
Cutout is 11"x15" with a 10" depth and a 3" drain hole.
Thanks,
Boz
pateco
Aug 12, 2014
2,207
Thanks,
Boz
What happened to the original?
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
I was able to locate a double sink online thru camper supply stores. will check when I get home for paperwork and send to you.
BO.. How about trying that spray you see on TV. The guy sprays a screen in the bottom of a boat and goes out on the water.
Likes: pateco
Mar 20, 2011
624
BO - I bought my replacement sink from www.rvandvansurplus.com
my double sink size from PO is 25x17 (obviously PO cut out a larger footprint) - you can see what RVandVan has to offer or check with other RV type places. one additional search is a bar sink but it may not have your depth. good hunting
boz86
Sep 30, 2012
29
That's a great link, I owe you a drink :)
The 101-1-2 model you linked is a 2" drain, the OEM is a 3 1/2" drain. So I called the company your link takes me to, www.katom.com, and they were able to order a 101-1-1 for $149 plus shipping and tax. A way better deal than my link.
Thanks again,
Boz
Likes: pateco
pateco
Aug 12, 2014
2,207
Thanks again,
Boz
Glad to help. My boat has the same sink, so if it goes bad, I now also know where to order.
Jan 11, 2004
65
Hunter 31_83-87 Middle River, MD
Boz, I bought the Katom sink and it was a direct replacement. Thanks for the link. Now I need a drain that fits the sink. the opening in the bottom is 1-7/8" diameter, and the depressed area has a diameter of 3". I have searched and so far no luck finding this size drain. Any advice is welcome.
SFS
Aug 18, 2015
2,101
Currently Boatless Okinawa
I'm going to have that same problem then. Looking forward to any help out there.
boz86
Sep 30, 2012
29
My sink hasn't arrived yet, so I don't know what I'm going to have to do. You might call Katom, they seemed very knowledgeable and helpful. If needed, I'm also going to check with the plumbing supply store up the road, and if they can't help I'm headed to the RV parts place.
