Galley sink drain leak
Jun 30, 2010
40
Catalina 310 Bristol RI
I have leak in the galley sink drain. In the attached photo the black ring is loose and I can’t tighten it any further. Has anyone else had this problem? Catalina does not have a part to replace this for my 2004 model.
Catalina 320 Dana Point
The sink drain on yours appears to be a 3.5 inch kitchen sink drain to which the forespar sink drain is attached. Most are tightened to the bowl using a large threaded ring, yours uses those bolts as a clamp that doesn't look like it works.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
And while you are in there messing around, check the drain hose.
Mine (1988 O’Day 322) were badly rotted…I left that thru-hull open many times last year. Over the winter, I check it and was shocked at the condition…
Greg
