FW: Lines led aft
Oct 31, 2019
230
Jack, the wooden risers appear to be made of teak. They are thru-bolted
through the cabin roof with large washers. There are no backing plates
(although, if I were doing the job, I would have put some in) and no
sign of stress or leaking inside. The traveller is thru-bolted with
large aluminum backing plates. Trev (V2915)
________________________________
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of j.hunter9999
Sent: December 25, 2009 5:22 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Re: FW: Lines led aft
Trev, I am also interested in how you attached the wood. Did you use
something on the underside of the fiberglass, as well as the wood
beneath the winches?
Thanks,
Jack
