The tech rep said it is a common installation and for a small system like mine (35 amp alternator output) it shouldn't make much difference, so I was not intending to wire my alternator output to the battery terminal as the wiring diagram for the ACR shows. It look like you run the alternator output to a separate fuse block.
Scott,
That is a very typical installation the only problem is that either bank 1 or 2 can be the start battery. You don't need to fuse your alt but if the big starter wire has a fault and grounds the jumper between the alt and starter post is likely going to become the fuse.
I asked him about fuse protection for the start cable and if I'm not mistaken, I was told that it normally isn't done (amps are potentially too high and fuses would blow too often?).
This is generally true on much bigger motors than sailboat AUX engines. I have never blown a fuse on a sailboat aux engine from starting. This can happen on large diesels with lots of mass and high compression such as a big Cummins, Deer, Cat, Mann etc. but I have never once had an issue with a small diesel aux.
I have measured the inrush starting current on my 44HP four cylinder Westerbeke at a max of about 165 amps but this is only for a split second. Many of the starters on small diesels are under 1Kw rated. The M-25 for example is a .8Kw...
I actually used to own a Cummins 220B in a down east boat and started that on a regular basis off the 6V house bank which had a 300 amp ANL which also never blew from starting loads..
The other option to fusing is to contain the start battery cable in a conduit all the way from the battery to the starter as this too satisfies the ABYC standard. Fusing the start bank is not mandated in E-11 but in order to not do so they want the cable protected by conduit and an on/off switch. You as a boat owner do not have to do any of this. Catalina's idea of a "conduit" left me with a dead short to the motor so I am grateful I was fused.
I notice you make use of positive and negative buss bars? Is this redundant for a reason?
Not redundant I just have a bunch of hot and grounds to wire and I am not a big fan of stacking multiple lugs on a single post so I use buss bars.
I also have the shunt for the battery monitor, but my wiring diagram shows a cable to the engine ground directly from the system post on the shunt. You seem to be bridging to a negative buss. What are you bridging with and is it necessary?
No not necessary but I like the cleanliness of the install. The neg buss goes direct to the engine and all the loads are tied into it on the load side of the shunt. I used a piece of brass as my jumper after sizing it for the load as this is cleaner than another short piece of 1/0 wire.
The three fuses on the far left are also buss bared together, like the shunt, to give me the correct fuse sizes for my alt, battery cable and battery charger. The house batt comes into the top of the middle fuse. The fourth fuse on the left is for my inverter and is not on the battery buss but is powered off the battery switch feed via the hot buss bar.
There are thousands of ways to wire this up I am trying to be as ABYC E-11 compliant on my re-wire as possible but it is tough to do to the letter....
Clearly you are suffering from some sort of engineering disorder. I'm not a doctor but I'd say that one of the 9 openings in your body has bearing on the picture you posted.
I love you man,but you need to go sailing in the worst way. I'm thinking sunfish, something with out a bilge pump.
PLEASE get yourself some help. I'm genuinely concerned about your state of mental health.
Perhaps you can come visit when they commit me...
