Fuses for Truecharge 20 charger
412
Catalina 27 Victoria BC
Hi, the instructions for the Truecharge 20+ state that 25A fuses are required in each of the positive legs of the DC output side. An AC breaker is also required on the input size. For those of you that have installed one of these (or similiar) how have you done this on the DC side? In-line holders?, A separate fuse block? Circuit breakers? Thanks! David
May 26, 2004
168
- - Oriental, NC
Small fuse block
David I feed the charger from a AC breaker on my AC panel dedicated to it. I ran the output of the charger through a small fuse block mounted on the inside of a plastic container on ceiling above the battery bank. Hope this helps. Good Winds Dave M s/v DAMWEGAS
Jun 1, 2004
412
that helps
that is the way I was leaning as I was not fussy about in-line holders...
