fuse panel with no power
Mar 31, 2018
29
Hunter 30 Rockland, Maine
1976 cherubini hunter fuse panel has no power . Looked for loose ground but unable to find any, suggestions?
Nov 30, 2015
1,343
Got it. Are your batteries wired up good, any corrosion on posts, 1-2-all-off switch set correctly. Do you actually have fuses rather than breaker switches? Share a bit of your troubleshooting and that’ll help get some feedback from others here. Pics help too!
May 27, 2004
2,057
You didn't find the 'ground' loose or, you didn't find the ground wire?
Jan 18, 2016
782
Catalina 387 Dana Point
Trace with a DMM or even an analog voltmeter (if such things exist anymore)
Start at the batteries - follow each lead. At some point in time you'll find out that the voltage 'stopps' and that's where your problem is.
Beneteau 323 Annapolis MD
Near the battery there should be a fuse to protect the wire that feeds your panel.
