Fuse location for 361
24
Beneteau 361 Marina Bay Richmond Ca
Is there a fuse for the (110wa) Battery Charger... and if there is where is it... tks reply....
Oct 6, 2010
119
Beneteau Oceanus 321 Carters Pt.
We have a 1997 Beneteau 321 With battery charger located in cockpit locker (port side)
There are 2 fuses -one for each battery bank-locaten inside the charger cabinet.
Note we have since removed the original charger and installed a smart programable charger.
Dec 10, 2010
24
actually i found fuses for most of the instruments behind the instrument panel by the nav table.... but i cant find a fuse for the 110 charger.... not in the cockpit ,.,,, tks advise...pn
Dec 10, 2010
24
i have an other question... maybe you can tell me what kind of bulb i need to replace the anchor light .... if i knew we or i would only have to go up there once....thanx again...
Beneteau 323 Annapolis MD
While there might be a fuse in the charger's chassis itself, there is most likely just a cricuit breaker on the AC distribution panel.
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
If you could wait until the weekend (max) I could tell you the answer. I have replaced mine with a LED one but I have kept the "original". I will have a look at it and let you know.
But do we have the same one? Mine is a French built Beneteau Oceanis 361 Clipper and the light (not bulb) is a Hellas unit (see the photo).
437
pdnervo I haven't forgotten you. I still haven't managed to find the stupid bulb. But I will look again. I know it's somewhere in the boat...
