Fuse Caps
Jamie Taylor
I have a 1984 Cat 30 with the original fuse units on the control panel. My problems is that the fuse caps are starting to wear and/or the fuse has arced to the top of the cap itself. Anyone know where I can get replacement caps with have to replace the whole fuse unit?
C
Chuck Reed
drill out the fuse
I found the same problem on one of mine. I used a drill that was big enough to fit in the cap. Only took one or two turns and the old fuse was out. This will give you time to find replacements.
