It has problems
I don't own one but one of the families in the club does. The only advantage I could see is that it makes furling and un-furling the main easier. The disadvantages are numerous. You have to modify your out haul in most cases to allow the car to move all the way forward, the sail would need a sunbrell strip sewn into the leach to protect it when furled, you can't us batons, you can't reef, the luft is only supported by a small diameter rod fastened at either end so it adds a bow to the luft when the sail fills with wind, all the force from the sail has to go through the 2 end bearings so loosing just one means no sail, you really can't use your existing sail as it will "get all baggy" when you try and furl it, a cunningham can't be used, when you try to use the halyard to straighten the luft the furling rod just bends more....... It really takes away most of your sail controls.IMHO this is a "cool" thing used to sell boats to lazy folks who are only interested in sailing on the perfect day and then not wanting to do any more work than is ABSOLUTELY necessary.
