I recently purchased a 2010 Beneteau 31, which normally comes with a conventional mainsail as standard equipment. However, because I am just entering my 60's, I thought that it would be easier for me to have an in-mast furling mainsail. I did not know two things:
(i) the bottom 18 inches of the furling mainsails on these models tend to come loose from the slot on the mast so that it will not feed back into the mast when pulling the inhaul at the end of the sail - the fix is either climb to the mast and shove the sail back into the slot or use a stopper knot on the inhaul so that the mainsail cannot be fully extended (which affects performance). The dealer has promised to replace the sail with one that will not come out of the mast slot, but in the meantime my sailing is somewhat compromised.
bob on la bise
(ii) the foot of the mainsail is not attached to the boom. I never realized that was the case. Are all furling mains not attached to the boom? It seems to me I am losing a lot of air under the mainsail that would have been captured if the sail attached to the boom.
Any thoughts on either item would be appreciated.
bob on la bise
