DECORING, PINNING, FURLING LINE LOAD/LINE SIZE
Decoring is the removal of part or all of the core of double braid line. Decoring that section of the line which actually spools onto the furling drum allows more or larger line to be used. The rest of the line is left intact so as to be easy to hand and effective on the winch and /or cleat. Decoring is easily done by making a bight, compressing the bight to partially spread the external strands , using a fid to extract the core from between the external strands at the place where you want to cut the core, then extracting the cut section out of the rope at that point, making sure the inner and outer layers are not heat-sealed or connected in any way at the bitter end.Concern as to line strength should really not be an issue. If the line is large enough to be easy to hand, then it's most likely strong enough. More important is choosing a line that works for your hands and whatever winch or cleat you use it on. StaSet might be OK, but StaSet X is too stiff for decent furling use and is better suited to halyards.Another concept to consider is the difference between a fully loaded furling drum and one that is partially empty. The more line on the drum the larger the effective diameter of the drum and the more torque exerted on the foil, hence easier furling. The converse applies if you have problems with overriding turns, although overriding can be eliminated by careful feeding out of the furling line under slight load when pulling the sails out. Also, at the very least there ought to be 3 or 4 extra turns on the drum when fully furled, to assure success when furling in heavier air when the furl is tighter and requires more turns to accomplish.Pinning a furling drum while underway is hardly a safe thing to do unless perhaps you have a trip line connected to the pin, led back to the cockpit. Pinning should only be done when leaving the boat at anchor, mooring or dock in expectation of higher winds, short of removing the sail in extreme conditions.
