C
carisea
I have a 1992 p-42. The roller furling manual is for a hood system but the furling drum does not look like the one shown in the manual. I want to replace the furling line but the line does not go thru the drum shaft/barrel but rather feeds thru the bottom flange of the spool. The knot is between the bottom of the spool and a lower housing. I should point out that the entire drum assembly is below deck in the very bow point of the boat. It would appear that the lower housing can be dropped by removing three plastic screws. I can only gain access to one of them . I have tried every tool I have including a right angle screw driver but have no room to work. Must I try to remove the entire furling system from the below deck pit to work on this line replacement? Any Suggestions would be appreciated.
