Furler sail/cal 2 25/2 27 question
2,391
Hunter 28.5 Chesapeake Bay
As with most things about boats, it all depends....
If the groove in the furler extrusions on both boats takes the same size sail tape on your sail, the answer is that the sail from the Cal 25-2 should fit the Cal 27-2. The real question is do you really want to use it? I believe the luff spec for the 25 is 33-ft and for the 27-2 is 36-ft. So, even if the sail fits, you would be giving up a big piece of potentially usable sail area and performance.
