I have Furlex 200 furler on my boat and just ending my second season with this unit. Every now and then, the furling line jams when I'm trying to furl up the sail. This has been pretty annoying, but so far I've been able to clear the jams without too much trouble. In talking to the distributor, he has advised doing the following: reduce the amount of line on the drum when the sail is furled, make sure the exit angle from the drum to the first fairlead is 90-deg, make sure the system is lubricated, maintain slight pressure on the furling line when unfurling the sail, and make sure the halyard tension is correct. I've done all these things. I still get a jam now and then. The distributor -- a nice guy who is knowledgeable and wants to help -- says that this is the best I can do or expect and and that all furlers jam now and then. I disagree. I bought the Furlex, which is near the top of the line in price and supposed quality, to avoid having a system that jams or you have other problems with. All the other furlers I've have (Hood, Shaeffer) hardly ever jammed. What do you think?
