Furler parts
Mike
I have a roller furler on my O-DAy 25 and I need an upper swivel. There is no manufacturer name or ID. Any idea where I can find a generic equiv?
Don Evans
Take It To A Sail Loft
Mike, I don't know that any upper swivel will work, there is probably enough design difference between them, but since lofts are selling lots of RF's these days and the sails cut for them, I would seek an expert's opinion on replacement. What's your issue with it? Does it have a bearing race? Don
Trevor - SailboatOwners.com
Take it apart
Hi Mike - Don's suggestion of taking it to a sail loft is a good one. Is it currently jammed, tight, working at all? Perhaps you could take it apart and check the bearings. What condition is the lower drum? There should be some sort of mfg ID on the lower drum, but if not, a sailmaker might be able to help. Worst case scenario, it might be time for a new furling system. Best, Trevor
Mike
never had one!
my furler never had an upper swivel. I climbed up the mast and attached the head of the sail two years ago when i first got the boat and was trying to figure out the rigging. worked ok but had to go up the mast to take sail off for isabelle and now want to install it right...trying to find anything that will work. appreciate the help guys. Mike sv Anam Cara
