I bought a new Schaefer Snapfurl 700 furler and installed it this afternoon. I removed a CDI FF2 furler and the original stock Doyle jib. All went well except the sail tape is too big for the slot in the new furler.
The sail worked perfect with the CDI furler in terms of fitting into the slot and being able to raise and lower the sail with the halyard.
Schaefer specify to use a #6 tape on the sail for this furler. The slot in the Schaefer furler looks quite a bit smaller than the one in the CDI, they also specify a #6 tape on the luff. I used a silicone lubricant that is recommended for furlers to attempt to slide the sail up the furler slot but it was so tight after getting it about 24" into the slot I was afraid the sail would be damaged pulling on it any harder.
Has anyone else experienced this problem with Schaefer furlers ? Solutions ??
Bob
Bob
