Furler Installation/ sail fit profurl c320
Beneteau 323 Annapolis MD
If those straps don't raise the drum high enough, simply call Profurl with the length you desire and they will hook you up.
My slip neighbor had a problem with those long tang-type straps on his C30. When furling, there was so much play in the straps and pins they would rotate/twist in the process. He got a bar of ss, had it bent in a u shape to fit the clevis pin. Still some slack, but not as much. $$$
2,288
C30 Event Horizon Port Aransas
I had the same concern when I saw it on the internet. But after I put these in the drum assembly, it feels like they are precise enough that there is little slack.
I think it could twist up to 15 degrees or so with out effect, because the drum and the foil sections are connected, the tangs and cage are a free floating thing anyway. And the line is lead fair by a boat mounted lead. But I know what you mean I wouldn't allow any slop going on there either. anything that's not rotating should be stiff and held in place. I may get it installed this weekend.
The lap links are held in by the pin below and appropriate washers to keep it stiff. Mine never move.
I also posted a photo of ours showing how far off the deck they are on hermits parallel thread on this topic.
