CDI FF2 Roller Furler
I recently bought a CDI Roller Furler off Rudy Nickerson at D&R Marine a couple of months ago and I plan on installing it myself with the help of a friend of mine who installed one on his boat. I think that one of the most important things to do before you install it, is to make sure that your fore stay has toggles on it. My mast on my 222 has slots for "T" fittings. So I bought a Dwyer Mast tang off Rudy, that I will have to install on my mast in the vicinity of the slot on the mast. I also needed to have some clearance for my anchor roller on my bow, so that the bottom of my furler wouldn't be in the way of my anchor. so I bought a five inch Stainless Steel plate to add to my bow stem where the furler is going to be attached. I had Rudy cut my old "T" fitting off and add a toggle fitting to my forestay where it is going to be attached to the mast tang. This spring I'm planning on attaching the mast tang with duct tape, temporarily, and attaching the stay to it. I'll hoist the mast up to get a rough idea of the tang placement. Then I'll mark it and have Rudy rivet the tang in place with his hydrolic press. You may have to find a mast rigger and talk to him about the toggles and stay length. If your mast has tangs, and your forestays already has the toggles, then all you have to do is figure out the proper plastic luff length. Once you have that all squared away, then you may want to get that CD rom instruction video. Also, you'll probably want to take your sail to the sailmaker and have him evaluate it. The sail will have to be cut down and he'll have to remove the luff wire and piston hanks, and install the tape to the sail luff where it slide into the plastic luff on your forestay. Also, if the sail is in excellent shape, you should have a UV cover sewn in to protect it. Otherwise the sail will only last about three seasons. The conversion will probably cost about $350 with the UV shield. It may be worth your while to have him make you a new Genoa for $50 or $100 more. This is something that he can advise you on. Rudy's shop is only about 8 miles from where I live, so I'm lucky. When the time comes, I'll probably bring my boat down to his shop and have him rivet the tang to my mast. You may need to make two or even three cuts on the plastic luff, to get the proper clearance up top where it attaches to the mast. The luff need to be at least 3 inches from the mast so it doesn't hit it when it's spinning. Also, the CDI Furler can be purchased with or without ball bearings. Rudy advises that you don't get it with the ball bearings on boats our size. All you need is the metal washer that comes with the furler, that the drum sits on. According to Rudy, the ball bearings will get stuck and bound up, in time. The ball bearings can also be added later if you feel a need for them, but that furler will work just as good without them. Get someone to give you a hand with it and take your time. Good luck.
