Furlboom Adjustment
20
Hunter 430 Hampton, Va.
I've got a H430 which the previous owner had a Furlboom installed. Of course during sea trials it worked perfectly but now it wants to ride forward on the boom and end up wedged against the mast. Does anyone out there have this product that can give me some insight on how to adjust this so it will consistently raise and lower without shifting?
Feb 27, 2004
134
Hunter 410 N. Weymouth, MA
Furlboom
Dennis, the angle of the boom sound like its off. all these in boom furlers are quite finicky about the boom angle. 89 degrees is the optimal angle. I've actually marked my main sheet at the proper angle so I do it right each and every time. since the sail is riding forward, you probably have the boom angle larger than the 89 degrees. i.e. the aft of the boom is too low. although its not as accurate as marking the sheet, if you eyeball the first batten as it's furling, it needs to be precisely parallel to the boom. this will get you pretty close. once you get it right, mark the vang or sheet as to the location. I prefer the sheet since my H410 has boom end sheeting. I'm in the owners directory if I can be of more help. I've had my furlboom for 8 years and it really works great, but it did take a bit of work to find the right angle. Bryce
Mar 14, 2007
20
Furlboom
Thanks for the advice. I had no owners manual to go by so it would have just been a guess. I'll give it a try next weekend.
