Funny splits / pierce throughs in the mast
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
If Ross is correct, and he may well be right, the mast should not be compromised.
Ross
Jun 15, 2004
14,693
If the edges of the slots are ragged and show a granular structure then the cause is probably corrosion. If there is great concern about crack propagation then a stop hole drilled at each end of the slot will distribute the stresses. It is possible to initiate corrosion on aluminum with a graphite pencil mark.
I doubt that the slots were deliberately made.
