G
Geoff in Ann Arbor
Well, I'm back at the desk safe and sound, and in one piece from our trip up to the tip of the Bruce peninsula in Ontario on Lake Huron. All in all Lesley and I had a good time, but things got pretty scary twice. I thought some of you would appreciate hearing about our experiences.Earlier in the summer I experienced engine trouble which I traced to the fuel/water separator being full of water. Also the filter on the engine was waterlogged, so I emptied all, put in new filters and chalked it up to poor maintenance by the previous owner, and myself as a new owner. Engine ran great after that, until...Tusday we were out in four foot seas in ten knot winds headed to an anchorage about an hour away when suddenly the rpm's dropped. I went below to check the separator, and sure enough it was full of water. I emptied it and got the engine up and running again but the rpm's continued to fluctuate as the water still in the lines was used up. I found that the only reliable position that I could maintain without the engine dying was to keep the rpm's at 3100.Well, as fate would have what should happen along at that very moment but a large thunderstorm. We were about two miles out on a lee shore so I decided I'd better head out into the wind until the storm passed. When the waves reached 8' with the engine turning 3100 (which I couldn't reduce) the prop cleared the water a couple times, so I made the decision to risk a run into the bay, which by that time I was directly upwind of. I had anchored in this harbor a few nights before and had a bread crumb trail on my GPS to show me the exact course until I reached the channel marks. Running down those eight foot waves with their short sequence made for some more than interesting helmsmanship. Again I had to keep the revs up or risk stalling the engine. As we approached the bay the waves got even more intersting as the water became shallow, but the mouth was big enough to get through safely.Once inside we got to our anchorage and because the wind was blowing decided to set an additional anchor. I keep the spare anchor in a stern locker so once we got the main anchor set I brought it forward and manouvered the boat to have Lesley drop it. I had stupidly put it's loop over the bow cleat instead of tying it on, and, ... you guessed it ... we paid out all the scope and watched with horror as the loop slipped off the cleat and the line sank. Fortunately anchor #1 was good and stuck so we rode out the night securely. Next day I snorkeled for about an hour in twenty feet of water when I finally gave up. The water in the bay just wasn't clear enough to see the bottom.I did a thorough job of cleaning the fuel lines, and got the motor back humming along. I chalked the problem up to bad fuel somewhere along the way.Saturday, we left Kincardine, Ont. for the 46nm trip across Lake Huron back to Harbor Beach. Winds were 5-10 kts., predicted to increase to 10-20 in the afternoon, then reach gale force by evening. I decided to make all haste by sailing with main and jib, and with the motor running. Our course kept us nicely between close hauled and close reach (mostly close reach) so we were making 7 kts. most of the way. Our expected arrival time was 2 PM, plenty of time before the wind change.All of a sudden, about fifteen miles out of our destination the engine sputtered and died. Went down to the good ol' fuel separator and it was full -- of water. I emptied it, but must have gotten air in the line because the engine wouldn't start. Then of all the luck, the starter solenoid stuck on so I had to kill the battery switch. I decided that we could make 6 kts. under sail, so we should just keep heading to home. I notifed the Coast Guard the we would be coming in under sail, but once in the harbor would need assitance since it was looking like we would need to anchor out in gale force winds -- with only one anchor.Well, we made it into the harbor by about 3:30, the winds had definitely piped up to 15 kts. I headed up and dropped the sails while Lesley dropped the anchor in fifteen feet. After paying out 250 feet of scope we were dragging very quickly toward the rocks. Eventually the CG grabbed our anchor rode and towed us off -- within about 3 ft. of hitting the rocks. Once we were towed clear the coxswain hailed me and said "Captain, how close did you come to the rocks. over." "About 3 ft. over.", I replied. To which he said: "I usually try for two inches. over." (Ten thousand comedians out of work, and he's trying to be funny.)Eventually we borrowed two anchors from a friend in the marina, and got 'em all stuck for what I thought would be an interesting evening.But then suddenly, the wind just died. So we decided it was safe to go in tow alongside our friend's 28' power boat back to our slip -- where she sits all snug, and safe, and sound.Where is all the water coming from? I was chalking it up to bad fuel and poor maintenance, which might have been part of it. But upon inspection of the fuel filler screw cap, the o-ring is entirely shot. All cracked, and split, and hard. The other caps -- water fill, and holding tank -- were the same or worse. The fuel filler is in such a position that water running down the rail is forced right over it. In calm waters the engine is fine because the tank doesn't get stirred up enough. On starboard tack, the boat heels over and the pick up line is on the port side of the tank so it's able to suck the water off the bottom if there's enough of it.What made the solenoid stick? I do not know. Once in the slip I was able to disconnect the wires, tap on it a few times, and now it seems fine.Where to go from here:- tank will be pumped dry of contents- new o-rings on all screw caps- fresh fuel- inspection of separator every time prior to leaving harbor- troubleshoot solenoid to see if it needs replacement- reassure my brand new beautiful wife that sailing is fun -- mostly
